Abrasive Blaster
Abrasive Blaster
okay i was gonna buy a spot blaster and use it to blast some parts on my car such as the door jambs and the area between the door hinges and the from wheels and under the top of the cowl...i think u know what i mean....anyways...i got to thinking, yeah it would probably work for those areas, but i might as well spend a bit more and get a big sand blaster and just have it so i can use it for when i repaint my engine compartment too and other stuff like that.....
http://www.harborfreight.com/cpi/cta...temnumber=9588
do you think that would be decent?
RE: Abrasive Blaster
yeah, well i went to the harbor freight store and that one is only online so basically it was buy this pressurized 20 gal for like $50 or buy a spot blaster for $14 and so i just bought the spot blaster, im going to go try it out....
I also used one from HF with glass bead. Worked fine for the engine bay, not tried the doors. Whatever material you use, it gets into everything, so airblast later to get rid of any residual material from the car, spray down with a hose, then airblast again, especially where you will paint.
I also have a $100 blast cabinet from HF, what a timesaver.
HF had the 20lb pressurized on clearance for $39. As "some" have said if you know what you are buying from HF then you can get good deals,. There are good deals to get you just have to be a little smarter then the avg joe. For instance a $19air nailer??? I have used it in a side business for 6 years (Deal or no Deal????Deal)The sand blaster was awesome and did the engine compartment in one evening. Look on their online store and go to clearance, this is where you will find the better deals.
Don't buy the import crap!
There is one spot blaster that works, it is sold by Snap-On. It is made by Unitec and is called a Speed Blaster model 007. You can run several diffrent types of abrasive, and it has a ceramic nozzle that costs about $8 to replace.
Google Speedblaster 007 and you should find it for about $45.00 (DONT BUY IT FROM SNAP-ON UNLESS YOU FEEL LIKE SPENDING $70)
Here are a couple places selling it for about $45
http://www.tooldesk.com/products/pro...il.aspx+id+688
http://www.usatoolwarehouse.com/usat...e/uni-007.html
Peter
Peter
