Mustang Fastback Side Vent Drain Hose
Old 05-04-2007, 01:16 PM
gothand
gothand's Avatar
Default RE: Mustang Fastback Side Vent Drain Hose
Jim,
Mine does not have the hole on the floor. Instead, it has two 'slits', about 1/4" wide x 3/4" long. It really looks like the thing was designed to hit the splash shield and run to the floor where it drains out the hole. I don't know how much water actually makes it into the vent drain, but there isn't a spot of rust anywhere on the floor below the drain.
I'm wondering if this is a '66+ item. Sentipede's '65 doesn't have the hoses either. Hmm ...
gothand is offline
Old 05-04-2007, 02:42 PM
66GTKFB
66GTKFB's Avatar
I looked at both the 65 Mustang Weld and Sealant Assembly Manual and the Ford Car Parts manual and there is no reference to the drain or the hose. It's is possible that this was a running change and because most non pressurized hoses used were a cut from bulk item, the was no attempt to provide a service number. Because the hole and drain fitting are part of any replacement sheet metal part or assembly, it would not be referenced. It's there, it's looks like a good idea and if it was not present, I would consider adding the feature. Unless you are like me, I don't drive my Fastbacks in the rain - it does rain in California, like right now.
Jim
66GTKFB is offline
Old 05-04-2007, 04:14 PM
Timelockmind
Timelockmind's Avatar
You're right - I counldn't find a reference number either. My shop guys tell me that they have seen many fastbacks with major rust in this area - primarily due to no drainage.
Timelockmind is offline
Old 05-04-2007, 06:58 PM
gothand
gothand's Avatar
Rain in CA ... ba ha ha, we've barely had 3" down here in L.A. I feel like a raisin. It rains so infrequently here,it'llrarely see water. I'll take a picture tonight to show the drain holes in my '65 to see if they're like yours. As is, I'd have to take a hole saw to that area to connect a hose to it. I may just do that, though probably with an adaptor so the hole doesn't get too big.
gothand is offline
Old 05-04-2007, 07:12 PM
66GTKFB
66GTKFB's Avatar
Their's manditory water rationing in Santa Cruz, can't water your lawn - wash your car,and most of the SF Bay counties are requesting a 10 percent cut back. It seems that Texas is getting all the water.
Jim
66GTKFB is offline
Old 05-04-2007, 07:16 PM
Soaring
I ♥ Acer
Soaring's Avatar
We are about 10 inches over the normal rainfall here in central Texas. Everything is as green as poison.
Soaring is offline
Old 05-04-2007, 07:25 PM
66GTKFB
66GTKFB's Avatar
Were about 2/3rds normal but there's enough run off from the Sierras to fill up most reservoirs so we ain't in trouble yet. It's going to be a long hot dry summer (margaritas, aah) thanks to Algore (and the increased output from the sun)
Jim
66GTKFB is offline
Old 05-04-2007, 08:04 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
We are as dry as a popcorn fart and burning down. Two large fires within 25 miles of here...and no rain in site.
Pray for rain.
fastbackford351 is offline
Old 05-04-2007, 08:12 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: fastbackford351
Pray for rain.
When it gets dry in Florida, something's wrong. Tell ya what though. I stood in line at Epcot center several years ago, and I thought that Florida sun was going to boil my brains. Dayum it's hot in Florida. [:@]
Soaring is offline
djbigskrilla
09-20-2022 01:04 AM
NTO_GUY
12-24-2015 11:23 AM
kiwi4100
08-18-2015 10:45 AM
kiwi4100
08-16-2015 08:39 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: Mustang Fastback Side Vent Drain Hose
