T10 or toploader?
T10 or toploader?
Need opnions....Just purchased what was supposed to be a toploader for my 66 coupe...when he brought it I saw it was a T10. The coupe has a 3 speed now but want the four. Should I stay with the t10 or sell it and get the toploader. Can I get a reverse lockout shifter like the factory? Which is stronger and where can I find the ratios. Thanks for your help.
RE: T10 or toploader?
Never owned a T10 but I am happy with the toploader I bought from David Kee Toploader Transmissions. As far as ratio, the Toploader came with either a wide ratio or close ratio. Here is a page from his website with the specs.
http://www.davidkeetoploaders.com/torqueandgear.htm
ORIGINAL: 67coupe
Is your T-10 cast or aluminum? If it is the old long cast iron model I would rather have a top loader. Most T-10's have a tall 1st gear. Mine is a 2:84.
A Borg-Warner T-10 is a good transmission. However, it is not as strong as a toploader. It is also susceptible to breaking the 2nd and 3rd gear synchros with a stronger than average engine.
Most if not all of the parts needed for aT-5 conversions shown in www.mustangsplus.com including bell housing adapters.
Jim
Jim
ORIGINAL: 66GTKFB
Most if not all of the parts needed for a T-5 conversions shown in www.mustangsplus.com including bell housing adapters.
Jim
Jim
simmons look around http://moderndriveline.com/index.htm they have every part youll need.
