bored over 40
Old 08-18-2007, 09:42 AM
  #31
cprstreetmachines
cprstreetmachines's Avatar
Default RE: bored over 40
ORIGINAL: JMD
ORIGINAL: my77stang
while i agree that taking out more than you need to is stupid (your shortening the service life of the block), i wouldnt feel bad at all about .040 or even .060 on anything older. maybe some of the later model blocks cause everything seems to be thinner, but the older stuff i say game on.
and btw your not overheating cause the motor is .020 or .030 or w/e it is over, your overheating cause your cooling system isnt doing its job, or needs to be improved.
I really don't understand how thinner cylinders create overheat issues anyway,,,, as far as I know, whatever heat enters one side of a casting (combustion side) must be drawn away from the other side (water jacket side),,, heat in, heat out.... IMO, no matter how thick the cylinders, their use as a "heat sink" is extremly limited... to the point of being all but moot..
I could see thinner cylinders contibuting to uneven expansion and cylinder distortion when hot,,, but I can not see issues with increased overheating....
Thinner walls makes it easier to pass the heat from the cylinder into the water jackets, making the water hotter, so on and so forth. But if the cylinder is thicker, it will retain the heat more in the cylinder and then go out the exhaust. If you find a freak small block Ford with clyinder walls that would still be at .125 thousands thick after a .60 bore, it would not over heat anymore than a bone stock motor, stock bore with walls that are .125 thick.
cprstreetmachines is offline
Old 08-18-2007, 10:17 AM
  #32
my77stang
my77stang's Avatar
just an FYI, any cast oem replacement pistons, or most of the hyper. pistons are destroked to compensate for boring and decking the block, thus keeping compression the same or even lowering it.
once you get into the performance hypers, or forged stuff they are generally not destroked anymore.
my77stang is offline
Old 08-18-2007, 10:24 AM
  #33
RobbieG.
RobbieG.'s Avatar
The 302 in my sons Maverick is .060 over and we have no problem with it here in Phoenix. You just need a good fan and Rad to cool it.
RobbieG. is offline
Old 08-18-2007, 10:30 AM
  #34
my77stang
my77stang's Avatar
^ thank you
Old 08-19-2007, 06:50 AM
  #35
Gary H
Gary H's Avatar
Ask your machine shop if they can sonic check a block. If they cant, then they have no idea how big of a bore a block can take. And a .030 overbore only adds 3 cubes. And at 1.5HP per cube.. 450HP, that only 4.5HP. Engines are bored to remove wear, scratches etc from the cylinder wall. The more HP you make, the thicker you want the cylinder walls.
Gary H is offline
Old 08-19-2007, 02:23 PM
  #36
66GTKFB
66GTKFB's Avatar
ORIGINAL: Gary H
Sanity returns.
Jim
66GTKFB is offline
Old 08-19-2007, 02:28 PM
  #37
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: 68EFIvert
"Bored over 40" ........... HMMM, at first I thought I logged onto the wrong forum. It sounds kinda like a singles forum......
What's that old C&W song? Oh yeah......"Older Women Make Good Lovers. "
Soaring is offline
McLeary
03-14-2016 07:50 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
JayGee
09-15-2015 12:41 PM
FivePointToTheOh
09-14-2015 03:35 PM
Faolan65
08-27-2015 06:40 AM
Quick Reply: bored over 40
