New Motor Mounts = HUGE vibration!! :( REVISED
So I put new poly mounts in and I have ran into yet another problem. I put the car on jacks and put it in drive....the driveline bounces up and down, and the leafs shift from front to back. The spot on the leafs towards the rear jump up, inturn moving the rearend up and is hitting the bottom of my car. There is fresh markings down to the metal so its definately hitting it hard. ALL THIS IS CAUSED FROM NEW MOTOR MOUNTS AND TRANNY MOUNT??? What do I do??
RE: New Motor Mounts = HUGE vibration!! :( REVISED
There is a serious bind , bend, or imballance somewhere...
I am assuming that the rear of the trany points pretty close to the yoke on the rear axle..... I can not imagine that the driveline is so misaligned that simple misalignment could be causing this... There is not enough room for this serious a misalignment....
Did you remove the driveshaft when you changes the trany mount? If you did, it sounds as though you have not bolted it back up properly. Check the U joint is central in the diff yolk.
Other than that, I agree with JMD ragarding a bent tailshaft, you didn't jack the car up by the tailshaft while doing the mounts did you?
It is def not a bent drive line. I used jacks under the frame when I installed the mounts. (and the drive line was left on also). It is possible that the deteration of the old mounts allowed so much play that when I installed the new poly mounts it caused the"shifting/play" to move towards the weaker point (the rear of the car). This is the only changed I made. It drove fine before this. So what else could it be?
ORIGINAL: 65PonyLove
Doesthe driveshaft slip yoke have room to move back and forth in the transmission?
Does your car have shocks on it right now? If not, the axle may be hanging low enough while the car is on stands that the drivshaft may be in a bind.
The nose of the differential and the tail shaft of the transmission must be parallel for a pair of U-joints to work correctly. This took me a while to get my head around. I thought a U-joint was for turning angles, so two joints could turn two angles... right? WRONG! The two must be parallel. If they were pointing directly toward each other, that works... because that too is parallel. If changing the mounts raised or lowered the front of the engine-transmission unit, it would fulcrum off the transmission cross member thereby changing the angle and taking them out of parallel. If this is the case, use wedges to alter the rotation of the rear end (lift or lower the nose). Hope it's that simple for you.
It does have shocks on it right now. And if I need to add wedges/shimms, where would I put them to make the angle correct again?? It sounds to my that the rear end needs to move up to match the mount moving the driveline up??? RIGHT???? Then would I put wedges etc in the springs.....I dunno but I feel like I'm getting closer....THANKS!
HEY ....TROOPER.....could I check the angle of my driveline with a construction level?? It might sound weird but from what ur saying where it connects to the tranny and rearend need to be at the same height so a level would tell me how much it needed to go in a certain direction, RIGHT??
jwog666
12-27-2021 08:09 PM
