gear vendors?
RE: gear vendors?
He is talking about Gear Vendors planetary overdrive.
It is like a gear splitter on a Truck... sorta.
They are neat, but I don't think I would go for one unless I had spent a lot of money on a non OD transmission. For the $2500 you would spend on it + what you would pay to have your driveshaft shortened you could swap in an AOD or T5 whatever your flavor.
Here is one slapped on a C6
RE: gear vendors?
Are you planing to use Gear vendors in automatic or manual trans? If you have manual trans have you considered Keisler kit?
http://www.keislerauto.com/ford/mustang65-70.html
Gear vendors will work fine, at least some of my friends use that and they like it. You get from your 3 - speed automatic with Gear vendors 6 -speed automatic and from 4 - speed manual you get 8 - speed manual.
http://www.gearvendors.com/hotrods.html
RE: gear vendors?
id just use a t5 tranny or a aod both have a overdrive gear and can bolt right in a early mustang.that gear vendors unit is pricey and you gotta fab up a tranny cross member maybe beat on the floor pan for room also have a driveshaft made.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
KingRando
10-02-2015 08:06 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
