cleaning the undercarriage
RE: cleaning the undercarriage
POR 15 is paint that can Paint Over Rust (hence the POR). Look around, there are other products that do similar things. Look in FAQ as well.
Oh, and welcome to MustangForums!
You could have the underside mediablasted. expensive but very effective, i have spent hours underthere with a wirewheel and it sucks, you have to get it clean before you can POR-15, but that stuff is great.
I've heard the opposite, there has to be some surface rust for POR-15 to adhere properly. If it's too clean (rust wise) the POR-15 will flake after a while. This is all hearsay, I have never used the stuff.
I would wire brush, and sand, as much as possible. Then I would use a liquid (not water) degreaser and wipe off the remaining rust dust. Then, I would POR15 the bottom. Generally speaking, you will have enough rust remainng for the POR15 to bite into. The reason it flakes off is more likely to be that the surfaces are not clean and dust free.
Get yourself a paper suite, with a hood, ear muffs, and duck tape (for areas likely to scrape. Put you car up on stands, nad start at about 8am. Around noon you should have made enough progress to have a beer...
