Progress and setbacks
Old Sep 10, 2007 | 08:40 PM
bluovalguy's Avatar
bluovalguy
Default Progress and setbacks
On Saturday, I finally got the rear leafs out!!!!!! Now I am just waiting on new leaf front eye bolts to get the rear end back together. Got the whole front suspension put back together. The disc brakes are not gonna happen now like I thought, so I am putting the drums back on. I took the drums to a shop to be sandblasted so that I could paint them to match the car, but for some reason, once the shop blasted the outside, they continued and sandblasted and primed the outside, inside, and the inside hub part with the races in it.
It all worked out though, the shop didnt charge me, plus I got new races and bearings cheaper than the sandblasting was gonna be. So I will turn the drums to remove the primer and I will have gotten the outside sandblasted for free
Old Sep 10, 2007 | 10:06 PM
baddog671's Avatar
baddog671
Default RE: Progress and setbacks
Good job. Match sure you clean out the cavity area up where the eye of the leaf springs bolt up. Mine had a bunch of dried junk stuck in the corners. I used an air-chisle to knock it all out, then got the rest of the loose junk off by hand, and hit it all with some rust converter and paint. Good luck...
Old Sep 11, 2007 | 04:51 AM
andrewmp6's Avatar
andrewmp6
why didnt you use the disc
Old Sep 11, 2007 | 04:59 PM
bluovalguy's Avatar
bluovalguy
ORIGINAL: andrewmp6
I dont have all the parts right now and need to save some $$ for awhile.
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Gene K
Oct 21, 2015 11:37 PM
Sep 27, 2015 03:16 PM
Sep 25, 2015 09:06 AM
allenmaty
Sep 24, 2015 09:17 AM
