how to take out the ignition swich?
RE: how to take out the ignition swich?
disconnect the battery.put the key in the switch,and turn to the acc position.(on) insert a paper clip into the hole of the lock cylinder.push the paper clip inward to depress the the lock pin,then turn the key counter clock wise and with draw the lock cylinder.press the rear of the switch and rotate it counter clockwise. remove the bezel,switch and spacer.hope this helps.
bradleyb
11-27-2015 07:50 PM
jessicarabbit
09-25-2015 12:41 PM
