66 Radiator Fan shroud???
RE: 66 Radiator Fan shroud???
Make sure that when you order it, you dont forget to add a fan shroud installation kit.
I forgot to order mine and only received my fan shroud. Pretty dissapointing when living over the ocean and having to wait for parts for 2 months.
first hand, I put the fan shroud on my 66 and made a major diff, added the four core and i can easily drive any 100 degree day and sit at a stop light without a bit of concern. that shroud is an absolute necessity if your in a hot climate.
If you have an I6 motor understand the shroud is not square and will need modifying of the brackets to mount to radiator or support,, I just bought/install one for a 66 200 ci engine and found that the shroud is not "square" as it doesn't bolt to the mounting brackets,,,in other words if you gotta 289,,,you can probably buy a shroud and mount kit ( the brackets) and it'll work outta the box,,as far as helping,,,DO IT! everyhelps
Heh, I still managed to put my thumb into my clutch fan while yanking off my vacuum advance. I think the only reason I didn't breakthe knuckleis because it's a clutch fan and not solid...
Seanam
10-04-2015 10:15 AM
09-25-2015 09:06 AM
