electrical problems 69 mustang
ok first let me ask... if my distributor is not hook up will that cause the fallowing problem.... ok so i put in a good battery today... i hooked it up and grounded it to the block... its reading 12 volts going to the solenoid.... but when i go to turn on the lights to see if all is hook up right ( since the car has been in the process of restoring since feb) and i have no juice... what could be causing this?
RE: electrical problems 69 mustang
yeah the coil isnt hooked up because i have one of those distri. that have the coil built in... personally i dont see how having the distri hooked up or not would make a differance.. especially since i need to run a hot line from my ignition to my distributor... and as of right now with this problem, my ignition has no juice
also, could having my alt. hooked up wrong cause the problems im having... just a reminder im not trying to start te car.. im just trying to see if my lights, dash and interior lights work.
Power is supplied to the car through the big black (with some blue paint on it in this case) wire with the ring terminal on the upper right. Make sure you have it on the correct side of your solenoid.
jcomp, i noticed that you have a 69 also.. i was woundering if you could do me a favor... could you snap a pic...or describe ur alt. wiring.. which wires go where.. ive been unsure about it....
ORIGINAL: eep4life
