some progress today
RE: some progress today
its not hard at all with an oil pressure gage. I made mine with a hydraulic gage from an industrial supply place some hydraulic line and some fittings. Napa also sells one for around $100.00 a shop would charge you at least $50.00 I am guessing especially sense it is in a Mustang.
Yep, I smoked a 700R4 which uses a similar setup in about 2 seconds at WOT......
My son was pissed.... we had just put his cam in and we were on a test drive... should have checked that out a lottle closer... and I knew it. Some of us never learn...
ORIGINAL: onegreedy
what controls the shift points on an aode from a 99 mustang?
its electronic its and aod(electronic)
yeah most assume that the tv cable is a kick down and as stated above its not its all about line pressure on those, i played with mine a little when i had one in my 91 i raised the shift points a little higher, and firmed them up honestly EZ post this up in the 5.0 section for more good info
One thing to consider... Some tachs need a full 12V feed to get a proper reading. I found this out after installing one into my clock hole in my 67. The factory ignition wiring only supplies ~6V to the coil, so you'd need to bypass the stock ignition resistor wire for proper functionality. Assuming, anyway, that you're pulling the signal from the coil terminal. If you're still running points, you'd have to splice into the resistor wire really close to the ignition switch to get a 12V signal.
What I'd do is have your favorite shop hook up a timing light with a tach, which will pull the tach feed from an ignition wire rather than the coil. You can compare this tach reading with the one on your column to make sure it's accurate.
KingRando
10-02-2015 08:06 AM
09-27-2015 03:16 PM
09-25-2015 09:06 AM
