rear suspension
Old 12-20-2007, 08:16 PM
bluovalguy
bluovalguy's Avatar
Default RE: rear suspension
I couldnt get the damn saw zaw to work, kept bending blades. I had great luck with an air chisel though. Really sucks I waited til day 4 to try it[:@]
bluovalguy is offline
Old 12-20-2007, 08:47 PM
390bigblock1
390bigblock1's Avatar
i think im going with 5 leaf 1/2 inch raise from the stock ride hight
390bigblock1 is offline
Old 12-20-2007, 10:03 PM
baddog671
baddog671's Avatar
They make 5 1/2? Prepare for a gut smashing ride..
baddog671 is offline
Old 12-20-2007, 10:45 PM
390bigblock1
ORIGINAL: baddog671
not that i know of im thinking of getting a 5 leaf kit, thats a 1/2 inch raise.
Old 12-20-2007, 11:37 PM
Scott H.
Scott H.'s Avatar
Scott H. is offline
Old 12-21-2007, 01:28 AM
mat11089
mat11089's Avatar
the front bolt comes out easy with an air hammer...
mat11089 is offline
Old 12-21-2007, 02:01 AM
390bigblock1
ORIGINAL: Scott H.
New HD shackle kit for the rear. Slather on the included grease. Being from California, I've never really had to fight with eyelet bolts, so I think it really depends on where the car has been (salted roads, etc).
I'm also a fan of using a local spring shop instead of *off the shelf* stuff. They can build you a progressive spring pack that gives a nice ride but has more bottoming resistance. Go to a local scale and get a rear axle weight with 1/2 tank of gas, and take that information with you to the spring shop. A good shop will ask a lot of questions, so they get it right the first time. Also doulble check that they use an American steel spring provider. From my experience this equates to better quality control, and greater spring life.
Lastly, on assembly just snug up the front spring eyelet and shackle bolts. Do not complete final torque of these bolts until the car is on the ground and you've backed up and down the driveway curb a time or two. At that point I like to back up a set of ramps, and torque to factory specs.
Good luck,
ya i use sac mustang they have all my cars specs, i cant take it to a scale because the rear spring is so bad and i dont have a back window in,thx for u help, and i wish i had air tools but i dont.
Old 12-21-2007, 07:32 AM
109jb
109jb's Avatar
ORIGINAL: mat11089
ThisREEEAAALLLYYY depends on how rusted it is. After cutting the bolts on mine I couldn't press the bolts out of the steel bushing that is in the middle of the rubber bushing with my 20 ton press (Midwestern USA salted roads). When putting it back together I would grease or never-sieze the crap out of that front bolt. 390Bigblock said his wasn't rusty, so I hope you are right and he has an easy time of it, but that's a bet I wouldn't take.
109jb is offline
Old 12-21-2007, 01:31 PM
390bigblock1
ill let you guys know how it goes when i start on the 26th
Old 12-21-2007, 01:37 PM
bluovalguy
bluovalguy's Avatar
Good luck. If you struggle, dont let it get the best of you. Not all, but most of us had a helluva time with it. Its just one of those PITA labors of love
Quick Reply: rear suspension
