how do you paint inside the rocker panel
I'm working on my '67 fastback floors. And i had some rust on the rocker panel so i cut it out and there was a huge mouse nest in there so i use the air compressor to get it all out and i noticedthere is some surface rust in the inside of the rocker at the bottom. What would be the best way to paint that? or best way to get rid of the rust? i can't reach all that much. will just pouring paint in there work? thanks for any help
RE: how do you paint inside the rocker panel
Can you possibly get some Metal Ready from NPD and spray it in there with a garden type Pump Up sprayer and then try to use the same method to spray some POR15?You should only need a Qt of each and it will cost about $60 total and the stuff is Great![sm=gears.gif]
my dad thought he saw some type of sprayer that sprays in every dierection, i'm looking to see if i can find that first. I thought with POR15 i could just use in over the rust with the only prep being removing "loose" chunks. is that not right?
