1967 restoration help needed?
01-17-2008, 10:18 AM
NEW BEE
Hay guys my brothers 67 coupe stalls when driving down the road for no f reason any suggestions?
Working on it now thanks in advance. [align=right]
[/align]
01-17-2008, 10:27 AM
RE: 1967 restoration help needed?
could be a number of things, check the coil wires and see if there coming off or grounding out.
01-17-2008, 11:09 AM
Trash in the fuel system [fuel filter] loose wire, like he said,any number of things. Process of elimination!
01-17-2008, 01:46 PM
when i first got my 67 stang i had the same problem, so i put premium gas in it removed the choke from my carb and never had a problem since
01-17-2008, 01:50 PM
There's obviously a reason or it wouldn't be stalling. Start with ignition, then fuel, then if still having problems, post results of those checks.
01-17-2008, 01:54 PM
Start with the basics! Fuel filter,loose coil wires,grounding prob,bad wires,etc!Good Luck and keep us posted!
01-17-2008, 02:21 PM
Just fixed the radiator. F leak. Will check what's suggested will post results.
Thanks
01-17-2008, 03:48 PM
You should give more details. Does it stall when he is accelerating, braking, letting of the gas, etc?
Dont go all out before checking simple stuff. If you have points, check those, be sure you have new gas, etc.
Johno29
03-24-2016 03:54 PM
alymac
08-26-2015 07:46 AM
mikecaputo
08-22-2015 10:58 AM
Johno29
08-21-2015 06:20 AM
defarmer
08-13-2015 06:40 AM
