Stock vs Aftermaket
Old Jan 17, 2008 | 01:40 PM
dugan's Avatar
dugan
Default Stock vs Aftermaket
ok. Can you get the same performance out of stock heads as you can out of aftermarket heads? what would the prices be compartiably(sp?)
Old Jan 17, 2008 | 01:45 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Stock vs Aftermaket
you can port some gt40s out pretty good, add bigger valves but you gonna end up not far off price wise from a set of alum head
Old Jan 17, 2008 | 03:14 PM
cmanf's Avatar
cmanf
I have a 289 with gt 40 heads and a 347 with afr heads no way no how even close to the same.
If the gt 40s are a fire cracker the AFR's are a A bomb in comparison.
I looked into the old 351 windsor heads then adding 202 valves like Model65 said your in the price range for some alu. heads anyway
Old Jan 17, 2008 | 03:34 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
You can certainly improve the performance of stock heads, but you would be hard pressed to match the performance of a good set of aftermarket aluminum heads.
Old Jan 17, 2008 | 04:09 PM
67mustang302's Avatar
67mustang302
By the time you modify a set of stock heads to perform as well as some good aftermarket aluminum ones, you're into it for about as much money, but out of room to grow. Most of the decent aftermarket heads are designed with more material and water jackets in different places so that they can be ported a great deal more. Plus aluminum is much lighter.
PaulH2
20
Jan 31, 2016 09:48 AM
mungodrums
Sep 29, 2015 09:18 PM
ccdguy
Sep 19, 2015 05:20 PM
