1966 Mustang, Change 6 Cill 20
Old 11-17-2003, 01:38 PM
bob emmerich
bob emmerich's Avatar
Default 1966 Mustang, Change 6 Cill 20
BillB, as stated by Wizbang, it's a relatively easy swap. However you will need a complete drivetrain(engine/trans/rear/driveshaft),frame and motor mounts,front spindles,V-8 radiator,alternator wiring,etc....Your 2.77 3-speed will not go to the V-8. The torque of it will destroy the tranny(if it could bolt on). You'll need to find the 3.03 V-8 3 speed,bellhousing,clutch assembly,flywheel, associated linkages. If you really want to hop up your six, try this website-www.fordsix.com. Those guys know how to do it, and it may cost less than doing the V-8 swap. I probably sound bias here(I like to keep cars as stock as possible) but why not try to acquire a drivable v-8 car instead, or if you're going to switch, keep(if possible) the six parts so there will be an option of going back to stock later-on down the line.
bob emmerich is offline
Urambo Tauro
09-07-2015 12:47 PM
landomar2014
08-17-2015 04:27 PM
SANDY21
08-17-2015 02:41 PM
daytooday
08-11-2015 09:22 AM
OBleedingMe
08-08-2015 12:02 PM
Quick Reply: 1966 Mustang, Change 6 Cill 20
