engine swap
Old 01-31-2008, 10:58 PM
azrdhd
azrdhd's Avatar
Default engine swap
can anyone tell me if a 76 or 77 351w will go into a 67 mustang that had a 289 by just swapping the motor mounts?
azrdhd is offline
Old 01-31-2008, 11:06 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: engine swap
dont even need to swap the motor mounts although the 65 style will provide a slight drop but will make plug changes more of a chore check out the faq on the classic home page theres more info on the swap and welcome to the forums
rmodel65 is offline
Old 02-01-2008, 09:13 AM
iamdiffrnt
iamdiffrnt's Avatar
The three issues I can think of off the top of my head are Hood clearance, alternator bracket, and power steering bracket. The first just means before you slam the hood after you swap, make sure you are going to clear the hood when it is closed, you may need a shorter air filter assembly. The second depends on whether your 351w still has it's alternator bracket or not, You may have to buy/make an adapter plate so the large bolt can attatch to the cylinder head and get a shorter bolt. The third depends on if your car has power steering, basically the same as the alternator bracket, either buy or make a bracket so the main mounting bolt can attach to the cylinder head.
Hope this helps
iamdiffrnt is offline
Old 02-01-2008, 09:58 AM
Starfury
Starfury's Avatar
You'd also need new exhaust manifolds/headers
Starfury is offline
Old 02-01-2008, 02:46 PM
azrdhd
azrdhd's Avatar
Sure is nice to have a place to come for help! I was looking at an engine the guy wants 100 bucks for, of course it will need rebuilt but I thought it was a good deal if it will work for my sons car.
azrdhd is offline
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
97SN95GT
09-13-2015 09:45 PM
mdj89
09-06-2015 11:08 PM
zachary1988
09-04-2015 03:04 PM
Quick Reply: engine swap
