painting headers
Old 02-04-2008, 09:45 PM
1967mustang
1967mustang's Avatar
Default painting headers
i bought some headerand i need to paint them, i was wondering what i should paint them with/ i was thinking, "Design Engineering High Temp Silicone" its good up too 1500 DEG. i heard depocolor if u use there 1200 DEg paint put in oven for 2 hours at 300 it make it better.
so i was wondering what i should do?
thx
1967mustang is offline
Old 02-04-2008, 09:52 PM
JMD
JMD's Avatar
Default RE: painting headers
IMO use what you think best, higher temp would probably be better, but you might consider any option to paint your headers temporary to one degree or another!
I read somewhere that the header companies consider their black painted headers as more or less "painted right up to the first startup"!
I have used bar-b-que paint with moderate short term success.... No experience with any better paint...
JMD is offline
Old 02-04-2008, 09:57 PM
rst08tierney
rst08tierney's Avatar
I did exactly what you wanted to do. BIG MISTAKE!!! The paint burned off. Spend the money on a new set your much better off.
rst08tierney is offline
Old 02-04-2008, 10:10 PM
JamesW
Moderator
JamesW's Avatar
Eastwood makes a high temp header paint that is pretty good stuff. I took a old rusty set of headers, had them sand blasted, then used this stuff. They came out very nice and lasted with a good finish for several years.
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
JamesW is offline
Old 02-04-2008, 10:27 PM
deebo68
deebo68's Avatar
You could Jet Hot Coat them, it's not cheap but it would be the best option.
http://www.jet-hot.com/streetrods.html
Deebo
deebo68 is offline
Old 02-04-2008, 10:43 PM
JMD
JMD's Avatar
ORIGINAL: JamesW
I like that option, I imagine that sandblasting would go a long way toward making the paint a lot more durable by improving it's adhesion by a large degree...
JMD is offline
Old 02-05-2008, 06:33 AM
JamesW
Moderator
JamesW's Avatar
Yes, freshly sandblasted, (use gloves to handle to keep the oils of your skin off the bare steel), then use a cleaner like Eastwood's PRE....then paint.
JamesW is offline
Old 02-05-2008, 08:09 AM
1967mustang
allright sounds good.. i just had buddie of my sand blast them. now where can i go and guy this eastwood paint? that insnt on the internet.?
Old 02-05-2008, 12:29 PM
nuts4fords
nuts4fords's Avatar
If you are going black, Barbecuer paint DOES work great, It's what I have used many times. And in most cases, it's a lot cheaper than VHT, etc.
nuts4fords is offline
Old 02-05-2008, 01:34 PM
JMD
JMD's Avatar
ORIGINAL: 1967mustang
JMD is offline
Quick Reply: painting headers
