Parts?
RE: Parts?
Pulling and installing is a 1 of 5 star job. I have a puller which you can get from autozone or anywhere for $20, but I did not even need it. Wheel slid off like butter. Some can be a little sticky though.
RE: Parts?
Look in the FAQ or on the Mustang Monthly site. They did a restoration of a steering wheel that doesn't seem too hard if you have patience and bare minimum skills. Restore what you've got and learn something at the same time.
RE: Parts?
Kalli,I thought the 64 1/2 and 65 were technically the same model year. Why would the steering wheel be different? (I know there's a difference between the generator and alternator cars in the 65 66 time frame)
RE: Parts?
alt and gen difference is between 64 1/2 and 65.
my horns did not work and I replaced about everything but the steering wheel to get it sorted, that's how I learned.
The 64 1/2 have a horn relay under the bonnet (sorry, hood) and the contact is a spring that goes into the 64 1/2 steering wheel.
you can't fit that in the 65 steering wheels.
here are pictures of the parts you won't find in any 65 car:
the horn spring:
http://store.cal-mustang.com/cm_able/showdetl.cfm?&Product_ID=6869&DID=7&CA TID=26&CM_SA=0
horn relay
http://store.cal-mustang.com/cm_able...19&CM_SA=0
65 steering wheel looks like this:
https://mustangforums.com/m_4379674/tm.htm
and my 64 steering like that:
https://mustangforums.com/upfiles/52...CE11C8D08F.jpg
(the circular hole in the bottom is where this horn spring goes)
maybe you get the whole thing going if you buy a 65 steering wheel with horn ring and all parts and redo your cabling.
But i'm not sure on that. Some mustang part houses say that they're not interchangable as well
Kalli
the horn spring:
horn relay
Kalli
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 06:58 PM
