20" to 24" Radiator Upgrade?
Completely rebuilt 289-4v Automatic(for now)...I don't want to run an old used up radiator in my brand new motor...I was wondering.....
Would it be smart to upgrade from a 20" to a 24" radiator...and if it would be...how ugly will it end up looking or will it bolt right in?
Tell me if I am wrong, when you rebuild a `67 Coupe (with 289-4v and in-dash factory a/c) from the ground up...ugly isn't what your looking to end up with...myself I am looking for one pretty a** muscle car.
Thanks for any help.
Tony
Tony
RE: 20" to 24" Radiator Upgrade?
Do a nice fit and finish and it will look good. Mines is I thing 40"wide had to cut the support and add some things still working on the fit and finish.
[IMG]local://upfiles/55786/645A811C5DD44EAE89D55E0AB2DEB43B.jpg[/IMG]
Thanks, Not really able to make anything with any metal, steel probably, not aluminum.
I am just looking to see if it would be difficult to swap out a 20" for a 24"....or would it be a waste of time.
Thanks again, nice pics.
tony
tony
ORIGINAL: 19tony67
tony
tony
I would have thought it would bolt right in, after you got the 3 saddle brackets? My 68 289 w/ac came with a 24" rad from the factory. if he has the bolted in side plates in his rad support (to keep air from going around the radiator core) seems to me it should be a bolt in. Isn't the small block 24" identical size wise to the big block rad? I thought the only real difference was the lower outlet location. [sm=insomnia.gif]
Anyways,I have been wrong many times before and will be many times again.
ORIGINAL: iamdiffrnt
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
