headlight extension part number
does someone know the ford part number on the headlight extension on the right side, I don't know if I have a 1969 fender or a 1970 fender or the headlight extension is 69 or 70 I can check the part number and figure out which part doesn't match
thanks
smokee
thanks
smokee
RE: headlight extension part number
Below are pics from an "Exploded View Illustration Manual".
Both years show the same part numbers for the extentions.
On the part you may see the number preceeded by "C9ZZ" on the 1969 or perhaps even the engineering prefix of "S9MS".
Ifthe part is marked with"S9MS" then thenumber that follows probably will NOTmatch the listed PARTnumber (16018).
So your part number on the item may look like C9ZZ-16018 for a 1969 extention.
I belive the '70may be preceeded by C0ZZ.
Anyway, hope this helps.
[IMG]local://upfiles/82243/01784C48F6B24B328E776C43222611E8.jpg[/IMG]
[IMG]local://upfiles/82243/B468F6B349C84603B9D5FC538218F816.jpg[/IMG]
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
