question about the 570 street avenger
after i get the car back together it has been recommended that i either go to the edelbrock 500cfm or the holley 570.
i have a question about the ports on the 570.
it has a powerbrake port by the secondary vacuum spring and the pcv under the front bowl
the current holley i am running (the little 390cfm) only has the large port by the vacuum spring. I had the powerbrake hooked to the manifold and the pcv hooked to the port by the secondaries.
does it make a difference. i would think that as long as there is full vacuum to both ports then it wouldnt but i just wanted to check first.
09-16-2015 07:53 PM
Daddys Girls GTs
09-14-2015 08:46 PM
