Will this shifter fit?
Hi,
This is the kind of shifter I would like to use with my T5, would it fit?
http://store.summitracing.com/partde...p;autoview=sku
Thanks!
Thanks!
RE: Will this shifter fit?
ORIGINAL: 67mustang302
As long as it mates properly to the shifter, the handle will work. It's going to depend on which shifter you use though.
I am going to buy a shifter stick and a **** that match but how can I know if it matches the shifter itselft?
This is the one that I used. Needs to be 7/8" cc on attachment holes. Ed Pitts
From personal experience and not just guessing for the sake of a worthless reply, yes, that shifter will work fine with your T5. It will bolt up correctly and the 10" length and 5.5" layback will position the shifter in a much more comfortable position than any original 5.0 type shifter.
The only word of caution I have is the thread size for the shifter handle.
It's....
ShifterStickBallThreadSize:
3/8-16 in.
....smaller than most aftermarket shifter handles. Most aftermarket shifter handles are threaded for 1/2"-20 thread size. You may have to use a threaded adapter to mate the handle to the stick.
Good Luck!
Dave
It's....
3/8-16 in.
Good Luck!
Dave
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
