Funky turn signals on '65
The turn signals on my '65 have been acting up for a while and i thought you folks might be able to help. The problem is when the lights are on and you flip on the left turn signal, the light on the right side goes out. Also, the right turn signal will only flash on and off, unlike the left with flashes on then brighter. What might be causing this to happen?
RE: Funky turn signals on '65
ORIGINAL: ClaptonFan
Thanks. The problem started (as far as i know) when i changed the bulb in the left signal, so it makes sense that it could have something to do with the bulbs. Also, the contacts are filthy so that also makes sense.
if you have to change your blinker switch in the steering column do not use a reproduction part. I have changed mine 3 times with repro's and i still have problems with the switches. they work for a little while but not long.
ORIGINAL: 69FECoupe
If you are speaking of your front outside turn signal/parking light, one or both of them probably have bad housing grounds.
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
