Big problem?
Big problem?
Well crusing out to the carshow last night i looked in my rear view mirror and saw smoke coming out the back of the car. I pulled over and i had tranny fluid leaking out of the flywheel. I noticed that i dont have an inspection plate down there so you can see the flywheel turning which was flinging fluid on my oil pan and pipes and causeingsmoke. Im not sure how big of a problem i have here. Anyone experienced this before?
RE: Big problem?
you sure its tranny fluid and not oil? either way your gonna need to pull the tranny to do it right. and the rear main seal would be a good idea while the tranny is out
RE: Big problem?
yeah. I would rather not spend anything on the fmx. Its been wineing and all kinds of wierd stuff. Its probably time to think about getting into a c4 or an aod setup like you said. I was looking into a rebuilt 5.0l fuel injected motor with trans to put in from a foxbody stang but im not too sure what kinda of mess i would be getting into if its really hard to do with the computer stuff and wiring. gas is a booger on the 351c.
RE: Big problem?
eh buy the efi off the mustang and add it to the cleve with an aftermarket manifold that has fuel rails made in like coast high performance offers. then wire it up and run the fuel lines. it would need to be a mass air setup(89-93) stang setup. then pirate the aod too. the tranny will work with the stock flexplate on the cleve so all you will need is a shortened d/s and a new crossmember and the linkage for the tv cable properly hooked up etc etc
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
