1967 289 distributor firing order
Old 08-04-2008, 10:03 PM
Pony67
Pony67's Avatar
Default 1967 289 distributor firing order
Hello, I'm newto this forum with a question that is puzzeling me. I have a 289 engine with pertronix ignition,mid cam, and Holley 600. I've recently replaced the spark plugs and noticed that the firing order was incorrect. The number 1 plug wire on the distributor islocated at the 6 O-Clock positionwith thefiring order for the 289 (15426378-counter clockwise). I tried to wire it correctly as stated in the repair manual with the number 1 plug at the 12 O-Clockposition and the engine just turned and didn't start. So, I rewired it the way that I original found it when purchased. I've owned the 67 since December 2007 and am finally finding some time to work on my car.
Does anyone have their distributor wired the same way? If so, why?
Any feedback is well appreciated. Thanks.
Pony67 is offline
Old 08-05-2008, 12:42 AM
groho
groho's Avatar
Default RE: 1967 289 distributor firing order
#1 is determinedwhen you drop the dizzy in the engine. It'sthe position of the rotor in relation to the cap. You can technically drop in a dizzy with the motor at any position, then locate TDC, identify the rotor position,set that plug wire for#1, and run you wires accordingly, set timing, and you should be good to go. Often, the vacuum advance determines the position of the dizzy, and #1 is usually in the 12 oclock position. Clear as mud?
groho is offline
Old 08-27-2008, 03:25 PM
Chris Brown
Chris Brown's Avatar
Default fireing order
Is your firing order 13726548 if so you have a 351 cam insted of a 289 cam nothing wrong it just gives you more horsepower.
Chris Brown is offline
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Drastang
09-30-2015 03:48 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: 1967 289 distributor firing order
