Ram Air
Old 08-14-2008, 09:52 PM
SuperHoss
SuperHoss's Avatar
Default Ram Air
Is there anyone on here that can give advice on adding Ram Air to my 66 or point me to a place that can? I want a true Ram Air setup...not just a hood scoop.
SuperHoss is offline
Old 08-15-2008, 08:10 AM
gbryning
gbryning's Avatar
Try
http://www.fordramair.com/
gbryning is offline
Old 08-15-2008, 11:09 AM
pushrodpower
pushrodpower's Avatar
Try this site as well http://www.ramairbox.com/product.html
pushrodpower is offline
Old 08-15-2008, 11:34 AM
urban_cowboy
urban_cowboy's Avatar
If you want a simple setup that is not ducted, I made my '69 hood scoop functional and then installed a K&N XStream air filter and lid. It is not great in the rain, but kick ars other than that. The air blows right down on my lid, which is also a cleaner so it flows straight down into the carb.
urban_cowboy is offline
Old 08-15-2008, 03:22 PM
groho
groho's Avatar
you're gonna have a heck of a time ducting to the front of the 66. I think your only option is to run low, below the battery or voltage reg. I was thinkin the same on my 66 until I noticed the tight spaces and the need for structural support. Now I'm considering a cold air setup and scoop, be a heck of allot easier.
groho is offline
Old 08-15-2008, 03:40 PM
pushrodpower
Ducting maybe be a pita but it will be more effective than the scoop. The factory scoop sits too low and too far back on the hood to really be effective, it sits within the boundary layer of air.
Old 08-15-2008, 03:49 PM
TexasAxMan
TexasAxMan's Avatar
You can move the battery to the trunk and get an alt. with an internal regulator, then the ducts can be placed where these once were. I'm thinking about doing the ram air but the pieces you need add up to about $250 or so, but I guess that's not too bad.
TexasAxMan is offline
Old 08-15-2008, 05:46 PM
Waffles
Waffles's Avatar
Location: Detroit; where the weak are killed and eaten.
I had considered, in the past, cutting into these headlight extensions on a 65-66 to create a ram air vent, then running the duct to the base assembly... like cvutting into the gills or louvres that already exist on the bucket...
Waffles is offline
Old 08-15-2008, 09:09 PM
1965fastback
1965fastback's Avatar
Waffles, I think that would work, if you end up doing it, post pics of it, i would like to see that setup.
1965fastback is offline
Old 08-15-2008, 10:48 PM
67mustang302
67mustang302's Avatar
Get a reverse cowl hood and seal the carb off to the cowl.
67mustang302 is offline
Quick Reply: Ram Air
