It's Painted! GT 351 :-)
Old 04-11-2009, 01:50 AM
Adrenolin
Adrenolin's Avatar
Thanks. Interior will be the two-tone Ivy Gold (light/dark). I think it'll look great once done.
Adrenolin is offline
Old 04-11-2009, 06:56 AM
Waffles
Waffles's Avatar
Location: Detroit; where the weak are killed and eaten.
parchment.
Waffles is offline
Old 04-11-2009, 07:25 AM
fakesnakes
fakesnakes's Avatar
It looks even more badass!!! I love the color and the two tone ivy green is exactly what my 67 convertible has with the dark green exterior and it looks fantastic!
fakesnakes is offline
Old 04-11-2009, 08:54 AM
andrewmp6
andrewmp6's Avatar
Looks great so far,If you run a aftermarket heat and ac like he is the cowl vent has no use anymore they suck air from inside the car not outside.Vintage air gives you a block off plate for the cowl vent with there kits.So smoothing it over like he did cleans up the lines and no way for it to rust out ever.
andrewmp6 is offline
Old 04-11-2009, 09:16 AM
bamadale
bamadale's Avatar
that green looks great!!
bamadale is offline
Old 04-11-2009, 10:12 AM
pascal
S197 Section Modder-ator
pascal's Avatar
Wrong shade of green!
Kiddin'
Good job sir!!
pascal is offline
Old 04-11-2009, 10:13 AM
Starfury
Starfury's Avatar
Lookin good
How does your Vintage A/C system not require the cowl vents? Where does it draw its air from?
Starfury is offline
Old 04-11-2009, 12:17 PM
Adrenolin
Adrenolin's Avatar
Thanks all.
Starfury.. It recirculates and uses the air from inside the cabin instead of outside. I believe all, if not most, aftermarket units do this now. As andrewmp6 said the kit even comes with a plate to block off the passengers side cowl hole. I had already blocked both sides off while replacing the upper/lower cowl sections. A round plate, some RTV and a few nuts... done.
I decided to seal off the drivers side Fresh Air vent as well. Without this masive vent we now have a pile of free underdash room available. This looks like where our Ron Francis fuse box, MSD 6AL-2 box & inertia switch will get mounted.
Old 04-11-2009, 12:50 PM
Starfury
Starfury's Avatar
Seems rather backwards. Fresh air is good.
Starfury is offline
Old 04-11-2009, 02:13 PM
Adrenolin
Adrenolin's Avatar
Open a window..
Really.. opening the vent windows or opening the windows gives you fresh air so I see no use for the huge fresh air bucket under the dash. By removing this and sealing off the cowl you also never (yeah yeah) have to worry about it rotting out again.
Quick Reply: It's Painted! GT 351 :-)
