Power steering control valve
Old 04-29-2009, 08:10 PM
larry67
larry67's Avatar
Default Power steering control valve
How do you seperate the ps control valve from the center link? I loosened the clamp but I'm not sure what is holding it tight. Is it friction fit or are there threads?
Larry67
larry67 is offline
Old 04-29-2009, 08:41 PM
flickjo68
flickjo68's Avatar
There should be a roll pin driven into the center link under the clamp. It looks like its a pin that you could drive out with a punch but you can only pull it out from the bottom. Once you pull the pin out, you should then be able to turn the control valve and get it off of the threaded part of the center link.
flickjo68 is offline
Old 04-30-2009, 08:42 AM
urban_cowboy
urban_cowboy's Avatar
Welcome to the forum.
It is threaded.
urban_cowboy is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
TfcCDR
09-14-2015 12:08 PM
BOBCATJACK
09-14-2015 02:18 AM
09-08-2015 11:50 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Quick Reply: Power steering control valve
