taurus fan for 351w 65
Old 05-03-2009, 02:01 PM
javier146
javier146's Avatar
Default taurus fan for 351w 65
Anyone running a taurus fan in 65 mustang with a 351w?
javier146 is offline
Old 05-03-2009, 02:37 PM
rst08tierney
rst08tierney's Avatar
just man up and buy the right fan. i belive the taurus fan is way to small for a 351
rst08tierney is offline
Old 05-03-2009, 08:52 PM
Iskwezm
Iskwezm's Avatar
you are incorrect.The Taurus fan will cool amost anything and blows more cfm then most off the shelf fans,
depending on your w/p to radiator clearance, you might have to trim the fan shroud.
Iskwezm is offline
Old 05-03-2009, 09:38 PM
Starfury
Starfury's Avatar
One of my buddies has a desert race truck that runs a Taurus fan. Like Iskwezm said, they push more CFM than most other stock fans. They have two speeds and chew up a massive amount of power when both fans are running, but they work great. You just have to figure out how to mount it to the radiator.
Another good option is a Mk VII fan. Similar fan that blows something like 3000CFM.
Starfury is offline
Old 05-03-2009, 10:02 PM
JamesW
Moderator
JamesW's Avatar
The issue you have to deal with is clearance. Depending on the radiator you are running, it may not fit.
JamesW is offline
Old 05-03-2009, 10:13 PM
eZ
eZ's Avatar
The taurus fan pulls 130 amps on startup so a 75amp alt will not be sufficient. Also finding a fan controller with a big enough relay is impossible so wiring becomes difficult. I kept burning up relays until I used a bosch 75amp. The fan pulls an estimated 2000 cfms and thats a real number not bs like the ebay fans. excellent for almost any hot rod.
And james is right fitting it can be very tight. My clearance is insanely tight.
eZ is offline
Old 05-03-2009, 10:14 PM
BeastMachine67
BeastMachine67's Avatar
I've heard of the taurus upgrade too..sounds interesting. if anyone has done it they should definately post it up with pics
BeastMachine67 is offline
Old 05-03-2009, 10:57 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
lincoln mark 8>taurus its actually the same fan motor but the pitch of the blades are different the mark 8 flows near 4k cfm
rmodel65 is offline
Old 05-04-2009, 12:16 AM
Iskwezm
Iskwezm's Avatar
I dont think it pulls 130 on start up, thats a bit high.We have only got it to spike to about 65-70 amps on high speed start up.I have a 80 amp relay and never had a problem or needed the expence of a fan controller,Ford only used a 40 amp relay.The cfm on high is rated above 3000 cfm (according to my Ford manuals)and the motor is the same for the Windstar,3.8 Mustang/Taurus.My fan is strong enought to suck thick rag and hold it onto the grill which is about 6+" away fornm the radiator core.
Iskwezm is offline
Old 05-04-2009, 06:31 AM
Joe67
Banned
Joe67's Avatar
4000 cfm?
you could mount the thing on the roof and skip the engine, add wings and you'd have an airplane =P
Joe67 is offline
Quick Reply: taurus fan for 351w 65
