Tranny swap in the coupe
Im going to be swapping out the C4 for an AOD in the next couple weeks in my dads coupe. What are a list of the parts I am going to need for the swap? Its a '66 coupe with a 289.
Thanks, Cody
Thanks, Cody
not sure of the complete parts list due to mine being already installed when i bought the car but i looks like cross member, throttle valve cable(mine is a lokar cable) dip stick, that is the only part that i can see but im sure their is more. you will love the aod
Im planning this down the road. some things doubled from above post.
trans
shift linkage
crossmember
converter
proper flexplate
yoke
some things can come from the AOD donor some cant.
http://www.mustangmonthly.com/techar...nsmission.html
http://www.fordmuscle.com/forums/tra...12-c4-aod.html
trans
shift linkage
crossmember
converter
proper flexplate
yoke
The AOD is just a bit longer than the C4 so the driveshaft will need to be shortened. Your C4 yoke may work for the AOD if it's the right spline count. I've heard, read, and seen yokes for sale that are listed to work for the C4 and AOD. But you'll have to shorten the yoke to work for the AOD as it has a longer tail shaft to work with in the C4 I believe. Or if you have a donor car then just be safe and take the yoke from the donor, much less hassel.
