carb gurus you are needed in mah thread
Changing jets around will just be hunting in the dark until you pull the plugs and inspect a good number of them. As 67mustang302 said, you need to look at the top of the porcelen for WOT coloring. It should be tan...not black...not white.
my77stang has a good point. If you are floating valves, the cam cannot work correctly. It is just like having a wrongly lobed cam because the valves are not following the correct timing. Typically at high rpm, you need stiffer springs to maintain contact between the valves and the rest of the timing system. 5500 is not very high rpm to have valve float, but if you have weak springs, it could happen.
Fuel starvation could also be an issue. What pump and fuel pressure are you running at those rpms?
What estimated horsepower & torque is this motor? With a stock pump and fuel line, you could be running low on fuel at WOT at higher rpms.
Will the motor rev to 6500 and stay there for a minute or so while out of gear under no load?
As for the fuel pump, it and that -6AN line might be too small for your fuel needs at race rpms...something to check out.
Even a stock pump is more than enough for his engine. Those hobby stock type engines are lucky if they can even produce 300-350hp out of a 350 inch engine. Pull the plugs and cut the threaded portion off, the base of the insulator should ideally have a very thin greyish ring about 3/4 of the way to all the way around it. Once it's all the way around it starts getting thicker. Anything more than about 1mm of width and you're too rich. 3/4 of a turn is typically lean best power, anything less is too lean. The ground strap should also show a color change(bluing metal or a greyish zone moving to copper) at about the apex of the strap. Closer to the tip is too little timing, closer to the plug body is too much. Also look for a greyish or brownish ring at the insulator tip where the electrode comes out, "ring around the electrode" as it were. A ring about .020 wide all the way around is a good indication of correct timing also, less ring = too much timing, thicker ring = not enough timing.
dochawk
08-25-2015 08:25 AM
