1965 Ford Mustang
1965 Ford Mustang
65 Ford Mustang convertible.
My horn does not work. I tested it by running a jump wire from the horn to the battery and the actual horn works so I assume the problem is in the steering wheel. Also, my turn signals work but have to be shut off manually. They don't "click" off automatically after you make a turn. Somebody told me these two problems could be related and have something to do with the steering wheel being put on wrong.
Can anybody help me fix this? I need to get an inspection sticker by the end of the month and the horn will be a problem.
Thanks!
Thanks!
if it's not a 64-1/2 (different horn setup) then you don't have a horn relay.
so test the following: take horn assembly off steering whee (the whole lot)
as I don't have the 65 assembly you need to check:
a) there's only one cable conneting to the horn assembly. if that's the case disconnect from horn assembly and hold the cable to the metal (the steering rod)
does that beep?
b) if you have two cables connecting to the horn assembly, disconnect them and short them (hold them together). does it beep then?
Kalli
does that beep?
Kalli
Sounds like you need to replace your turn signal switch. The plastic cam in yours is probably broken, and that's why your turn signal does not cancel by itself. There's at least a fair chance that replacing the turn signal switch will also fix your horn, since the horn runs through that switch too.
Thanks!
Thanks!
Note to Vince- Are you going to the Glazier/Nolan show next month?
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
NTO_GUY
12-24-2015 11:23 AM
08-10-2015 01:44 PM
