Alignment - Take to a Shop or DIY?
Old 06-30-2009, 06:38 PM
Norm Peterson
Norm Peterson's Avatar
Not intended as flame, but a $125 caster-camber gauge is a luxury rather than a minimum requirement. $20 or so will buy you enough common measurement tools to let you work to within less than 1/8°. $30 plus a dial indicator and some careful home-fab will let you work to somewhere down under ±0.05°, which is better resolution than the available steps in any alignment arrangement that uses commercially available shims.
Guess I should have mentioned the parallel strings and the 14.5° angle gauge (the $125 C-C gauge would likely use a 20° angle gauge instead). The strings are fussy to set up and are somewhat sensitive to the wind if you have to work outdoors, but they'll get you closer to the straight ahead and to reliably getting your sweep angles than you can do just by eye.
Norm
Norm Peterson is offline
Old 06-30-2009, 10:04 PM
Joe67
Banned
Joe67's Avatar
I've done more cars than i can count with just 1 length of string...
Easy, Accurate, And Cheap
Joe67 is offline
ChampInSD
10-02-2015 04:55 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
winner99
09-30-2015 07:04 PM
marc954
09-29-2015 11:18 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Alignment - Take to a Shop or DIY?
