Quarter window stuck on '65
Help,
My driver back quarter window is stuck on the down position. It was working fine but the back window handle now just spins and does not raise the window. I can't drive around like this...what do I do first? Do I have to remove the back seat, then the panel? What's the best way to attach this?
Thanks,
Thanks,
It could just be that the rollers have come off and the lift arms are out of the track. But if it is just free spinning and not doing anything, it sounds like it might be time for a new regulator. To check what is going on, you would remove the rear seat and then the inside panel. You will have to take off windless and may have to loosen up the sill plate as well as the front lower corner of the panel is tucked underneath.
Good luck.
Jeff
Good luck.
Jeff
