holley fuel pump good sucker?
Hi all,
http://www.summitracing.com/parts/HLY-12-125/
bought this fuelpump but forgot pressure regulator, so I have to order.
Would you think that is a good enough sucker to mount to firewall at the height of carb?
Or should I be safe and mount to back. problem there is that the pump is huge. nearly no way to mount without that thing scratching the road. or maybe other ideas
I'm even half thinking ov throwing the holley 570Street avenger back in and use the preset pressure of the pump (7psi). but would need to mount somewhere else as pickup is at front of engine...
Noooo. Electric pumps don't pull very well at all. That far away, you will have problems. Constantly moving pumps back to the rear for people. Last guy was a SBC in a 56 Ford pickup. Would work for a while, then over heat leaving him stranded.
There is a pretty good Spot just forward of the gas tank and just behind the pumpkin where a Holley pump and regulator will fit pretty good and is out of the way with relation to road hazards and other stuff...
I thought I had a pic, but I don't....
JMD: Will have another look. the summit pump i have, I made a bracket with loads of rubber. It's basically hanging from about where the front mounting bolts of the tank are. so it's currently right next to the fuel sender unit. the new holley pump is _huge_, so might have to come up with something different. now the new pump has the inlet on the right hand side, for this I need to mount to the right of the sender (let looking at it). painful ... or I just turn the pump around but I would miss on the nice looks of it. but noone's gonna see it down there anyway.
That's one of the reasons why I wanted it up front.
Tad: never thought of inertia switch. had a relay and oil pressure switch in mind (or STA terminal with relay), but that won't give me any fuel during start.
I'll ask a local car parts store to see what they can organise as inertia switch. Should be no bother fixing in if it's a simple switch with 2 connectors that are seperated on crash
We were able to fit a Holley pump there with some "creative plumbing"...
ah .. James moved out. didn't know. it would be great to see how you did it. I can see exactly that coming on to me ... creative plumbing :-) in my case that usually looks like a botcher job
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
