Fuel Level Sending Unit
Is it difficult to replace the sending unit without removing the tank? That is what the service manual suggests. Drain fuel, pull wire and hose, remove sending unit.....Car is a GT so no muffler in front of the tank.
Is the concours correct version with the brass float from scott drake a decent unit? Was planning to head over to John's Mustang and pick one up this afternoon. Did not seem like too difficult a job.
Suggestions or hints and tricks appreciated. Thanks!
Thanks for the help guys. Got er done last night. Went by John's mustang and picked up a new Stainless Steel pickup/sender assy. Siphoned gas out then drained the rest from the drain plug. Removing the ring holding the old sender was no big deal. Installed the new sender using a small dab of wheel bearing grease to hold the o-ring in place. Hooked it up and put 5 gals back in and the gauge works again! Not a bad job at all other than the gas smell and being carful with the fuel.
yourmom6990
09-14-2015 10:52 PM
09-08-2015 11:50 AM
