Headers for a mild 289?
It has power steering. What headers would you suggest? Short, mid, full length? The tri-y's have 2.5" collectors. Wouldn't that be a bit large? Primary size...1 7/8"?
Chrome, ceramic or just paint? Thanks all!
Ceramic coating is ideal as it will stay looking bright and rust-free for a long time. It also insulates heat well, keeping the engine bay cool and the exhaust charge hot. Chrome/nickel will discolor and eventually rust, painted headers will rust in short order.
I'd probably recommend either hi-po manifolds or tri-y's. Hi-po's will be the quietest, most maintenance free, and space-conserving of all your options. Tri-y's will improve power across the rpm band, but it's hard to find a good set of tri-y's. Most generic units are built in China and quality is hit or miss. Doug Thorley, FPA, and Doug's Headers all make high quality tri-y's, but they come at a price.
I'm gonna stay away from the manifold. I want the full benefit of the headers. Also trying to stay under $250 since pipe bending/fitting, tack welding, tips, etc. is running to $700, I want to stay under $1k for the whole exhaust system.
Wow, that's an outrageous price for tubing. Most shops here can do it for less than $500, including mufflers. Get some quotes from a couple other shops. Bring the mufflers to them if you want something specific and you'll probably save a couple bucks.
lol what? i had my whole system done for 400 flat, which included 2 flowmaster 44s. your welder fails
That may be and I'll work this price but remember, SLO doesn't have near the hot rod business traffic that Huntington Beach does. On weekends, I can't drive two blocks without running into a car show
If they do that much business, it should be cheaper, not more expensive. If it costs $700, it better be stainless, mandrel bent, and TIG welded.
Call a couple other shops, and drive out of the city if you have to. $700 is ridiculous.
I tired of the headers after many years, and switched to 289HP manifolds, port-matched to my heads. If you are using unported stock heads, your cam, headers, and dual exhaust are money wasted. A single exhaust with ported heads and exhaust manifolds would probably flow better than duals, headers, and unported heads.
