Rear Springs
Quite right! Proper springs will set the correct height, and using air or coil-over shocks will screw up your handling and ride, and eventually ruin the crossmember, which will cost serious money to repair or replace.
My answer was going to be any time you use air shocks you know it is time to change the rear leafs
You will be much happier with the ride once you get new leaf springs and replace the shocks. My car had air shocks and sagging leafs when I bought it. I did the 5-leaf Mid-Eyes and KYB gas shocks (cost < $300, and well worth it).
Yeah the air shocks belong in the trash.
The springs need to be replaced when they are sagging real bad.
I personally think the 5 leaf springs are overkill for most cars. I have GT springs on mine and it is plenty stiff.
I just finished the suspension sytem upgrade on my 68 coupe with Grab-A-Trak GT springs. The GT 4-leaf and coil springs will give you a nice ride over stock but firm. Here are the pics: http://www.freedomcruisin.com/Hollyw..._Projects.html
