Help with removal of a few things.
I can't figure out how to get a few things off of my intake manifold and transfer a small plastic piece for the choke plate rod from one carb to another.
First the carb, I want to take off the small plastic piece that connects the choke rod to the plate from my 2100 to put on the 4100 and I cannot figure out how to do it. I took the choke off completely last night but I could not figure out how to get the rod go high or low enough to get the tab on the plastic piece straight up and down. Any ideas or suitable subs for the 4100?
to
Then next I can't get the heater elbow off of the old intake to put on the new one. Soaked it in penetrating oil last night and still it won't budge, has it just been binded to the intake? Also the other connection for the coil on the manifold, hell I don't even know what it is, all I know is that the coil connects to it, can't get that off either. Can someone tell what it is and for?
Would it almost be more worthwhile to go out and buy the parts new for the manifold?
to
Unscrew the nut all the way, then turn the nylon fitting 90° and it'll pop out.
The heater elbow is just a pipe thread. If it dies when you try to remove it, you needed a new one anyway.
The plug is NOT connected to the coil, it's the sensor for the temp gauge, also a pipe thread. Just unscrew the whole thing.
Thanks, it honestly looked like the piece for the carb looked like one solid piece. I guess not having the best lighting does not help.
For the intake parts I can't get them to budge so I guess I might as well get some new ones. And I see what confused me with giving me the appearance it came from the coil. I looked closer and it is wrapped together with the ignition wire coming from inside.
I was never able to get that heater elboy out either, and u can find that engine temp sensor easy, just be sure you know what year its from. halfaway threw 1966 the changed the size on that piping so there are two different options.
But the heater elbow still would not budge. So I went down to the hardware store and got a brass new one, eliminated the need for the adapter for the new manifold.
Hopefully just about done with the swap, just have to reassemble a few things and then change the oil and refill the radiator.
