Removing dried 3M weathership adhesive
Old 09-01-2009, 07:51 PM
Adrenolin
Adrenolin's Avatar
Question Removing dried 3M weathership adhesive
As the title say.. whats the easiest way? I had to pull the trunk strip due to the fact the adhesive had separated and I guess it didn't adhere well. The weatherstripping also needed to be stretched a bit more. Unfortunately I now have a mess all the way around.
Adrenolin is offline
Old 09-01-2009, 10:20 PM
1965fastback
1965fastback's Avatar
Knife for scraping paint off glass, it should work.
1965fastback is offline
Old 09-01-2009, 11:03 PM
OCHOHILL
OCHOHILL's Avatar
Wire wheel on a grinder, ofcourse that takes the paint off too.
OCHOHILL is offline
Old 09-01-2009, 11:13 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
3m adhesive remover
rmodel65 is offline
Old 09-01-2009, 11:55 PM
Adrenolin
Adrenolin's Avatar
Ok.. new paint so the scraper and wirewheel are out. I was thinking more of what I might have on hand.. Varsol, Medium Reducer, Methyl Hydrate, etc. I know gently used they wont hurt the paint but will they soften up the adhesive for removal?
Old 09-02-2009, 12:02 AM
MonsterBilly
MonsterBilly's Avatar
Goof Off works fantastic
MonsterBilly is offline
Old 09-02-2009, 12:06 AM
Adrenolin
Adrenolin's Avatar
Never used it before but saw it somewhere yesterday... Canadian Tire maybe. I'll take a look in the morning. Thanks.
Old 09-02-2009, 03:45 PM
Adrenolin
Adrenolin's Avatar
Goop Off wins! Got the small can of it (not the spray) and it took it off the rear deck in about 45 minutes. The weatherstripping isn't as safe as I tried it on a small section and it started to eat the rubber after a bit of rubbing. I wound up wiping the Goof Off along the weatherstripping with about 4 or 5 passes which started to soften the adhesive. I then rubbed it off with Methyl Hydrate which dried the adhesive and it rolled off.
Old 09-03-2009, 12:25 PM
scootchu
scootchu's Avatar
Will that remove the yellow adhesive too? The PO used that on my trunk and I hate it. I have the 3M black adhesive, but went the wire wheel route on one door and would like an easier solution.
Now is it Goo Gone or Goof Off? I think I have both.
scootchu is offline
Old 09-03-2009, 06:12 PM
groho
groho's Avatar
WD-40 - is excellent for removing adhesives. It takes some elbow grease, but it's assured not to damage paint or scratch. it creates a slick surface so the adhesive doesn't want to stick. Use it all the time for tape, 3M, decals, etc.
groho is offline
Quick Reply: Removing dried 3M weathership adhesive
