Galvanized metal in car?
Are any parts of the mustang made of Galvanized steel? What about treating with zinc (Metal Ready). Would that make it a type of galvanized steel?
I removed all the paint, rust and glue from the interior roof of my car. And treated it with POR15 metal Ready. The paint I plan to topcoat (Rustoleum) with says not to use on Galvanized steel. I read in a thread last week that a Zinc coating was a kinda like leaving a galvanized coating.
I plan to paint/prime the interior roof areas with POR15 anti-rust paint, then topcoat with Rustoleum since the POR isn't UV resistant. Since I can't possibly get all of the tight/hidden areas along the doors and window frames, the rustoleum may come in contact with the bare metal in these areas. I'm sure the paint will come in contact with the bare metal areas I cannot clean or paint by hand (spray gun for Rustoleum) Even ford didn't get most of these areas. Is this OK or will there be some bad reaction between the paint and the metal if it's galvanized or zince coated? Will it peel, bubble, eat through it or even not stick to it?
Thanks all!
Thanks all!
The Headliner rods look lite GALV. What about the metal around the door openings and Windshield/backlight? The metal that goes up and around the door openings (inside the car that headliner rods hook to) looks like it may be galvanized. It looks grey, unlike the sheet-metal of the roof. Those are the ones I am really worried about using the wrong products on.
You aren't supposed to use rust reversers and removers (or rustolieum?) on any galvanized.
The areas over the door are not being painted directly.. But it may get overspray from painting in such a tight/enclosed space when I do the windshield posts.
I wasn't asking if I could use the paint on these areas. I wanted to know if I should go out of my way to keep paint off of it or any other specific areas.
Hope that clears it up.
Since galv metal is only a coating laid on top of regular steel I would assume you would have to grind it down really well to get the galv coating off the steel instead of a light sanding a cleaning with a chemical so it is down to true bare steel to be welded.
I've got replace mine on the drivers side, I got a full new outer and I got replace part of the inner at the least, I will know more when I get into that project.
Lynn
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
1965, car, galvanization, galvanized, interior, metal, mustang, paint, painting, panels, parts, recommended, rocker, rustoleum, steel
