85 f150 302/c6 swap into 70 fastback
11-16-2009, 08:11 PM
Found a good deal on a 85 f150 with a good 302 / c6. Will the c6 bolt up in my 70 with no problems ? Anything else I should be concerned with ? Would I need to change the distributer ?
11-16-2009, 11:19 PM
If the truck is a column shift the shift linkage will not work. Will need to change the valve body.
11-16-2009, 11:29 PM
I'm assuming the truck is a 2 wheel drive? If it's a 4X4, the transmission won't work. The main shaft won't be long enough to add a tailhousing to it.
11-17-2009, 10:20 AM
I doubt it has a c6...c4 is much more likely for a 302.
11-17-2009, 05:29 PM
OK , I bought the truck , but Im thinking Ill sell the transmission and just use the engine. Thanks for the advice.
11-17-2009, 06:17 PM
Why not just drive the truck?
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-24-2015 09:18 PM
1998 ,
302 ,
70 ,
82 ,
85 ,
c6 ,
chat ,
column ,
f150 ,
fastback ,
ford ,
linkage ,
mustang ,
room ,
shift ,
swap
