converting to electric fan ...
Old 02-04-2011, 10:37 PM
  #21
001mustang
001mustang's Avatar
Default Three strikes to raise an old thread
I was messing w/ my car and I tested fans. One relay was not responding.
I have two completely independent fan systems and this is the third failure in about 10 years.
1. Fuse lost continuity; did not blow.
2. Unsealed relay failed; replaced both relays w/ sealed type.
3. Blown 20A fuse; will replace w/ 30A .
I yanked out the fan on pump side. I connected both independent switched relay wiring systems to front fan. May carry my spare OEM 5 blade 1979 mechanical fan in the trunk when I go on long trips. Not sure.
Sure looks sweet...all that space in front of pump...now i can see that expensive march pulley system.
From a practical perspective it would be wise to run the 5 blade mechanical fan. Would minimize underhood temps and likely increase reliability; at the expense of beauty.
001mustang is offline
Old 02-06-2011, 06:20 AM
  #22
kalli
kalli's Avatar
wow ... that thread is one year old :-)
Since I got my cooling problem sorted I gave up on the idea
kalli is offline
Old 02-06-2011, 09:30 AM
  #23
001mustang
001mustang's Avatar
sorry
didn't think it was worth a new thread.
Old 02-06-2011, 12:30 PM
  #24
kalli
kalli's Avatar
Originally Posted by 001mustang
sorry
don't worry. so how is it going? any pictures of what you shoved in there?
kalli is offline
Old 02-06-2011, 12:48 PM
  #25
001mustang
001mustang's Avatar
i'm really enjoying that new found space between radiator and pulley.
now I can easily turn engine w/ socket wrench.
thinking about swapping to a solid flat tappet cam.
tired of the typical hydraulic valve collapse w/ high spring rate cams resulting in ticking.
i do have a pic of my geometry which is so so.
Attached Thumbnails converting to electric fan ...-0-ra-geometry-open-close.jpg
GPR
12-16-2015 12:21 PM
Seanam
10-04-2015 10:15 AM
LiquidDrink
09-29-2015 10:06 AM
09-10-2015 08:39 PM
Quick Reply: converting to electric fan ...
