Performance mods on a 66 w/ 302
Old 03-08-2010, 04:27 PM
302blue66
302blue66's Avatar
Default Performance mods on a 66 w/ 302
Hey guys I'm new to this forum and I was wanting to see what kind of advice I could get for building up my 1966 coupe with a 302. It's got headers, exhaust, 4 barrel carb, billet pullies, a very mild cam, aluminum heads, and a couple other little things. I'm wanting to make it higher performance and I was thinkin about putting some lower gears in the rear end with posi, a more aggressive cam, and a stall/converter. From there I have no idea.. Help?
302blue66 is offline
Old 03-08-2010, 04:51 PM
groho
groho's Avatar
personally, quick and cheap performance, I'd start by recurving the dizzy, adj'd the timing, and re-jet the carb. As for the trans (C4?) , if it's still streetable, change to a C-servo and adjustable vacuum modulator, and shift kit. the rear trac-loc third member and gears can be had for about $700. Don't forget your brakes! Good brakes are worth the money; SSBC, etc.
groho is offline
Old 03-08-2010, 04:59 PM
Gun Jam
Moderator
Gun Jam's Avatar
You could check to see which heads you have and then buy a cam, carb and intake to match them perfectly for performance.
-Gun
Gun Jam is offline
Old 03-08-2010, 05:51 PM
302blue66
302blue66's Avatar
I have drum brakes with a brake booster. Is that decent enough? and also I wanted some advice on wheels and tries to go with
Old 03-08-2010, 09:03 PM
guitarman376
guitarman376's Avatar
No! Disks!
guitarman376 is offline
Old 03-08-2010, 11:40 PM
64.5stanger
64.5stanger's Avatar
Front disc conversion 4 sure. Check discbrakeswap.com, opentracker, or chockostang.
64.5stanger is offline
Old 03-09-2010, 12:05 AM
Starfury
Starfury's Avatar
Discs aren't an absolute requirement. If you're only driving the car occasionally, and then usually in straight lines, discs may not really be necessary. But if you're driving often and/or on windy roads, definitely consider a front disc upgrade. Discs will offer more control during braking and less fade during repeated braking, but don't confuse this with stopping power. The factory drum brakes will stop the car just fine...just not always in the direction you expect
Regardless, a dual master cylinder upgrade should be considered mandatory. Single masters just aren't safe in the event of a leak.
As far as other upgrades go, the best bang for the buck will be rear gears. Of course, nothing will matter if you haven't already followed the advice in groho's first sentence.
Starfury is offline
Old 03-09-2010, 09:08 AM
stephen.osborne1
stephen.osborne1's Avatar
have you converted from points yet? BIG improvement in reliablity and some performance as you can open the gap some and run a stronger coil... Pertronix is easy and CHEAP!
stephen.osborne1 is offline
Old 03-10-2010, 05:54 PM
tx65coupe
tx65coupe's Avatar
I also recommend Pertronix Ignitor and front disc brakes. Its not necessary, but its a great upgrade.
tx65coupe is offline
Old 09-12-2010, 11:39 PM
302blue66
302blue66's Avatar
Already done the first 3 things. What gears would you recommend?
-Gun
That's my main plan. I've already got an edelbrock 4 barrel and an aluminum intake but I need a more aggressive cam and converter
What gears would you recommend? I'm about to put a positrac unit in it and I guess i could just do that while I'm at it. And how could I fix the speedometer afterwards?
I'll look into that
Quick Reply: Performance mods on a 66 w/ 302
