Water drip from exhaust?
Old 06-08-2010, 09:36 AM
MetalEd
MetalEd's Avatar
Default Water drip from exhaust?
I am not familiar with older cars at all. So this is new to me. It is a 170 I6 and has had just about EVERYTHING mechanical rebuilt from the carb back to the differential. I just got it to where I think it is reliable. This morning when I started to warm it up, I walked around the back and noticed that water is dripping out of the exhaust pipe with the exhaust. It clear and odorless, so I assume it is water. Is this normal? what could it be if there is something wrong with it?
MetalEd is offline
Old 06-08-2010, 10:11 AM
109jb
109jb's Avatar
It is normal. Hydrogen in the gasoline combines with oxygen during combustion to form a small amount of water. Once the car warms up the engine and exhaust system will be hot enough that the water formed will not be able to condense. It will come out the tailpipe as water vapor that you won't see. You should only get water dripping when the car is relatively cold.
109jb is offline
Old 06-08-2010, 11:38 AM
stephen.osborne1
stephen.osborne1's Avatar
my old shop teacher used to say that water was a byproduct of perfect combustion... I'd take that to mean your car is running great.
stephen.osborne1 is offline
Old 06-08-2010, 02:06 PM
67mustang302
67mustang302's Avatar
Water is one of the biggest byproducts of combustion. When a car is cold though and still warming up, and the temp drop throughout the length of the exhaust, the vapor condenses and drips out. All cars do it to one degree or another.
67mustang302 is offline
Old 06-08-2010, 03:39 PM
Norm Peterson
Norm Peterson's Avatar
One other thing about condensation is that if it's dripping from anywhere but the end of the pipe you'll know that you have a tiny leak and about where it is even if you can't hear it. The damp spot on the pipe pinpoints it.
It'll also show you where your exhaust line fabrication wasn't quite up to snuff.
Norm
Norm Peterson is offline
Old 06-08-2010, 06:28 PM
KMatch
KMatch's Avatar
One more detail on this indepth discussion: The muffler should be dripping from the end seams as well. Most are designed with a tiny hole in the seam to allow the water to drip out rather than fill up and rust. This is a feature and not a mistake.
KMatch is offline
Old 06-08-2010, 09:06 PM
MetalEd
MetalEd's Avatar
That's what I was hoping everyone wold say, but I thought it would be too simple. It is finally running so well after so many years and I had never seen it dripping or spitting water like that before, so I was worried about the engine rebuild and another expensive repair. It did stop after it warmed up and very light smoke (not trying to stall and all the dark smoke like before the rebuild )
Replace the front-end parts and the new floor boards are about the only two major things I have left and it will be a "new car"... That's basically the last two major items except the paint, minor body work and the interior upholstery/trim. It feels so good to have taken a completely rusted out car, barely able to start or move and bring it so far and back to life!
Thanks everyone!
MetalEd is offline
Old 06-08-2010, 09:59 PM
Oxnard Montalvo
Oxnard Montalvo's Avatar
Simple is good.
Each gallon of gas burned produces almost a gallon of water and twenty pounds of CO2, and it all comes out the tailpipe.
A quick read.
Don't Drink the Water.
Oxnard Montalvo is offline
Old 06-09-2010, 12:13 AM
67mustang302
Well, most comes out the tailpipe. Some ends up in the crankcase from blowby.
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
09-24-2015 09:18 PM
Quick Reply: Water drip from exhaust?
