A woman's project: 68 Fastback
#132
Here is a pic of the cowl painted. Tonight we will clear.
#135
Exciting!
I think a few layers of tape on the underside of the upper cowl would do it. Then beef up one end of the tape with lots of extra tape, punch or cut a hole through it, then tie a string through it and run the string out the drainage hole on the side. Then after paint you pull the string and assuming the beefed up tape holds, it'll peel off and be pulled towards the drain. Of course wait till the paint dries to do so.
That sounds a bit confusing but its the best idea I can come up with.
#136
Good question. I think what we'll do is cut a few pieces of cardboard to slide inside the cowl as well as several bunched up pieces of masking paper. We shouldn't have any problems doing it this way if we are careful. We are also cutting front vents in the cowl similar to the way Unique Performance and others have done so this will make access much easier.
#139
#140
The purpose of the vents is to aid in engine bay cooling. With the vents cut open it allows the hot air to escape, easier. It allows hot air to enter through the slits and out through the top of the cowl. With Old Air Product's A/C system, they close off the "fresh air" vents so we don't have to worry about any engine fumes or smells entering in the cabin. Another plus to cutting open these vents is access to the cowl for easier cleaning.
