Thought on front suspension
Old 12-15-2010, 05:04 PM
eZ
eZ's Avatar
Default Thought on front suspension
Well after drinking a six paxk last night while listening to metallicas greatest hits and staring at the mustang I started thinking..LOL
When I get roller spring perches the shock mount will roll more. that cant be good. Then I thought what if the shock had a heim joint! Like coil-overs duh. I looked at a kit on ebay for ron morris coil-over and thought the price was hilarious. Really all you have to do is make some plates to mount the coil over. I can have SS plates made for free.99 and buy QA1 shocks for about $300. Or you can buy the Ron morris kit for $830.99
http://cgi.ebay.com/ebaymotors/Musta...Q5fAccessories
So can I buy the shock with a heim in the bottom so that the roller perches will work like a double roller and then just fab the mounting plates up top? I may have to fabricate something for the lower shock mount.
What are your thoughts?
eZ is offline
Old 12-15-2010, 05:33 PM
gconnsr
gconnsr's Avatar
My personal thought is the stock spring perch in most cases has lasted for over 50 years, how long are those needle bearings going to last? But I'm more into restoration and keeping it as stock as possible so the only problem I see with the older mustang front suspension is the steering itself, I would prefer a rack & pinion set-up.
gconnsr is offline
Old 12-15-2010, 05:36 PM
Randys66gt
Randys66gt's Avatar
You must be a blast at a party!!!! I thought about taking a shock with an eyelet on each side and welding a lip on one side and call SKF to see if they had a bearing I could press into it all the way up to the lip. Never got the chance but I think it could be done, I thought complete roller, way to go.
P.S. If you decide to do it, I still have a couple phone numbers of head guys at SKF.
Randys66gt is offline
Old 12-15-2010, 06:12 PM
eZ
eZ's Avatar
Im just thinking of making a mount for the eyelet to mount to up top. piece of cake right. Well qa1 makes a kit that converts the bottom eyelet to a tbar setup that will bolt directly to your upper control arm. These companies are making a couple of mounts and then selling you a qa1 shock with the tbar kit for $900 LOL
eZ is offline
Old 12-15-2010, 06:20 PM
gconnsr
gconnsr's Avatar
That is one hell of a mark up, sounds like you could undercut the competition pretty easy! Roll with it man.
gconnsr is offline
Old 12-15-2010, 08:25 PM
eZ
eZ's Avatar
here is a universal shock mount for $12
http://www.summitracing.com/parts/AFC-20137
eZ is offline
Old 12-15-2010, 08:48 PM
tcrote5516
tcrote5516's Avatar
hmmmmmmmmm this man may be on to something.....
tcrote5516 is offline
Old 12-16-2010, 12:18 AM
andrewmp6
andrewmp6's Avatar
But spring replacement coil overs like that do nothing for the ride just adjustable height.If your going to do it they need to go down to the lower control arm.
andrewmp6 is offline
Old 12-16-2010, 08:42 AM
Starfury
Starfury's Avatar
In testing, John @ Opentracker found that the difference between his regular 'street' roller perches and his 'race' double roller perches is negligible in most driving conditions. The only time you might need a double roller setup is if you take your car to the track.
Starfury is offline
Old 12-16-2010, 11:55 AM
eZ
eZ's Avatar
My only thoughts are yea I drive mostly on the street. I drive about once a week. But there are times when Id like to rip down a windy road, through the hills. Id like to do the autocross at car shows. For sure Ill drag race the car. Eventually id like to take it to the race track but that wouldnt happen more than twice a year. So yea its mostly street drivin. but very spirited.
iThe reason I was deciding on doing this is if I purchase the roller perches, new springs, new shocks, Ill be over $300.
If I fabricate the top mount for the coil-overs Ill be just a bit over $300 and Ill remove the spring perch all together, adjustable shocks, plus better shocks to boot
eZ is offline
Quick Reply: Thought on front suspension
