MustangFTW 67 resto thread.
#42
A Flux Core cheap jobie runs on 110 volts and will burn right through the sheet metal, ask me how I know bro, I own the cheap machine you are refering to. Don't get me wrong they are great for welding thicker metal like the thickness of a quarter (as in money) or a bit thicker, but they splatter a lot. This machine does not use a gas tank, it uses a special wire that has the shielding built into it, actually around it. They claim to weld up to 18 gauge sheet metal but that is super optimistic.
Then there are the cheap 110 volt Flux Core / MIG welder combo units. They cost $200 bucks without the gas bottle. The gas tank will run you another $100 bucks, so for $300 you will have a mediocer machine.
just trying to help, I need a MIG machine too, I need to weld my floor boards too, check out the Eastwood machine and Lincoln or Miller are the top of the line (from what I've been told)
#43
Look at holbart welders. If i remember right their made by miller. I have one and we have had it for years now and done over 20 cars with it and every little project we have had. Think it was around 400-500 and they dont come with the tank and yes you dont need a tank but for good welds its a must other wise u get bird shxt welds.
#45
Guest
Posts: n/a
Havent been doing anything lately to the Mustang, going to take it in for a quote on the frame rail work, both rails are now separating from the floor =.=
its probably caused by the HORRIBLE roads in MN, the city is too lazy to pay people to fox potholes bigger then my tires and theres one every 5 feet.
Im thinking of a Power to manual steering conversion. saw this piece on CJ pony parts for 150$ supposed to attached directly to the centerlink and pitman arm. anyone know if this is easy to do? pics?
#46
I will have to keep an eye on your thread to see what people have to say about your conversion idea. Best of luck.
#49
Guest
Posts: n/a
i like the feel of manual more then power. heres the piece i was talking about.
http://www.cjponyparts.com/borgeson-...7-1970/p/MSA2/
#50
Guest
Posts: n/a
Anyway, screw manual steering for now i have more annoying fish to fry :P
my front right side is squeaking like a mad man, mostly the right sometimes the left, only when i go over bumps or potholes. im pretty sure i have to lube somethin just not sure what/where to lube any info will be appreciated. Also i cant tell if my idle is correct seems a bit high to me but im not sure, if i put up a video of the car running would you guys be able tell if its too high or too low?
